Wife and I decided it was time for a new fence in the backyard as the old one was close to original to the house that was built back in 2000. When we purchased the home in 2018 the fence was in poor condition then and it’s only gone down hill since then.
I ordered the materials and ripped out the old fence 100%. Set all new 4x4 and 6x6 posts, ran all new 2x4’s in between each post and the installed pickets. Picked up the welded gate frames this afternoon to work on over the weekend and while attempting to finish last 6 feet of fence line where it butts up to the house I started looking at how the old fence had done so in the same exact spot. The vinyl siding was slightly jarred so I decided to straighten it before proceeding and when I did I had some toothpick sized chunks of wood shake loose. I peered behind the vinyl and was not thrilled…
House was built without a housewrap and the old roof (replaced back in 2019) appeared to have dumped rain runoff down the chimney side. The new roof has a water channeling device up there to prevent such a thing and I believe it to be working as all this OSB was super dry and brittle. Fortunately, it’s only this one small side of the chimney, but it’ll be all of the 2x4’s on that side as well as the plywood there needing to be be replaced. Perhaps on Sunday I’ll get to it. Washing most of the day tomorrow and then I have to fill up a dumpster I rented to haul off all the old fence materials.
