Its getting there. I stalled the 55 gal drum today with E track and seems pretty solid. Out in the shop waiting on delivery of the rest. Built the Gilmore gun today as well. Gilmore gun may be a cheap DIY way to go but its probarbly cleaned half the roofs in America and if you watch an old Racer video he had really good luck with it. Gets distance and with an M5 twist i can go stream or fan. Put a ball valve on it as I dont want a sudden cheap gun leak and be a long way from being able to cut off the 12v.
Take that poly hose off that reel and use it for plumbing hose. That stuff will start to lay flat under its own weight and has memory to it so its going to kill your flow. Vinyl pvc rubber hybrid style hose is what you want.
Its coming off with 12v replacement line. Its 100 feet used with x jett and always served me good. But at 3/8 its to small for 12v.
Is the pillow to rest when you’re exhausted from running around trying to find the pressure washer that was secured with a zip-tie?
