Hello I have a home to clean with a lot of wood trimming. Has anyone cleaned anything similar. Was going to hit the stones with Xjet open but would be too hot for the wood I think.
use soap only no sh unless there are clearly pots with algae growth then just prewet with water, apply light mix of sh and rinse Rinse rinse well.
When you say a light sh mix are you talking like .5 ?
Sodium percarbonate for me
I only use gain @ the moment so just gain / water on the wood then? It doesnt look too dirty.
What would u hit the stones with.
I wouldnât use gain at all and those rocks donât look bad. I would use sodium percarbonate and a little Elemonator myself. Always start with the least aggressive chems if you can, especially when itâs not real dirty. Just did a house with percarbonate and Elemonator turned out great, customer was thrilled. SoâŚdonât always go to SH, many chems out there to get the job done effectively and safe.
I would just wash the entire thing with a 1000 psi tip from a safe distance. No sh on stained wood at all for me. Like said above only spot treat growth with very light sh and rinse real well. Recently I had an euphony that I can just clean most homes here in California with Soap and warm water. Been using green wash and terra wash only and itâs been working great.
You need to hire a professional for this job. Thatâs a nice house that you donât need to learn on.
Agreed, Iâm two years in and wouldnât touch that.
Example, I did a sizable white house with wrap around front porch this summer. He wanted âeverything whiteâ cleaned, and he also pointed out the porch ceiling is lacquered dark wood and ânot worry about it getting stained as itâs being refinishedâ.
Sure enough, a mild housewash mix spotted it pretty bad and honestly I wouldnât have realized it could do that. Thankfully he knew that after I mentioned using bleach before the job.
@dcbrock @Innocentbystander every once and a while its just smarter to walk awayđ a $600000. House with hardie plank painted blue gray ill pass lolâŚnot worth the insurance claimđ¤ŁâŚI just price myself out of the job
