Winterizing GX690
I got extra pump saver last season for this year, but since then I’ve upgraded from a threaded inlet 4GPM machine to an 8GPM which has a barbed inlet. I’m not sure how I should get the pump saver through my machine. What would you guys do?
Ditch the pump saver and just run RV Antifreeze through it.
Antifreeze
Walmart usually carries this stuff in the automotive section. If they’re out try Autozone or similar.
If that’s snow on your trailer, you’re cutting it close. :wink:
