I’ve searched and found many, many discussions about preferred boots and shoes for power washing.
BUT, does anyone have recommendations for boots or shoes for wide feet?
I normally wear New Balance Shoes size 11.5 EEEE width for a good fit. I looked up dozens of the shoes/boots recommended in other posts but as far as I could find most were standard (medium) width or many were slim/narrow widths. I would have to wear a size 12.5-13 of medium width shoes in order to sort-of fit but because they are so much longer than needed it’s not ideal or comfortable. Even typical ‘wide’ shoes are not wide enough - I need 4E width.
There must be some of you (or people you work with) with extra wide feet. What do you recommend for wide width work footwear?
I was wearing muck boot cool chore . They were great even in 90 plus degree weather. But like all good things they are not as comfortable as they used to be. Muck boots have gone way down hill.
Hat is the white one
So far so good but im very new to this business.
Held up to racers roof mix splashing down on my while i was holding the ladder so he didnt fall 40 feet down some difficult mountain houses.
This was my first time buying ariat . I’ve always like my muck boots . Wednesday was the real test 5 miles of Miami curbing. My feet still didn’t hurt. Record head over 100 degrees . They get a from me. Mine are the rubber boots though not the work boots
Made out of nylon and poly so water doesnt absorb and has mesh drain holes so any water in will drain out and will dry fast. Wouldnt be good in the cold but when is it cold in Florida. Lol
I’ve been wearing muck for years . There just not as comfortable as they used to be. The artists are way more comfortable than the last pair of mucks I had
Best work boots ive ever owned just not good for PW. I buy these about every 3 years got tired of laceing my redwings up and been wearing these ever since.
