I already pressured washed the driveway (no red tip, 3000 psi), here is some photos of my problem:
1 hosted at ImgBB — ImgBB - (Old driveway paint still present after 2 years, the material was cheap) 2 hosted at ImgBB — ImgBB - Some concrete discoloration (you can see lighter spots and darker, this is the main problem)
Is there any way to fix this? Some people were suggesting using muriatic acid, but anyone know some proven solutions if they exist?
Looks to me that there’s possibly a skim coat on top that’s failing.
And, perhaps, when the concrete was poured a plastic tarp was placed over it to prevent it from getting wet (say from a rainstorm). The awkward light blotches mimic what that looks like to me.
But, I’m not a concrete expert. Regardless, I doubt you did anything to cause that unless you used some crazy acid to clean/dissolve it.
You don’t have to use a photo hosting service, just click on the picture icon under the window.
Also some of that in the pic is just the magnesium in the concrete showing through, nothing you can do about that. I had a customer ask me to wash their back porch that was a year old and it looked worse than that so I told them it wouldn’t look any different.
