I purchased the whisper wash ultra clean 16". Any personal thoughts about it? I have a 4GPM machine.
I was concerned about the sealed bearings. Anyone had any issues with this unit?
When the bearings go bad, drop in another one. I have two that are at least 15 years old
Wait…bearings go bad?
I gotta get home fast.
No issues with mine, just use the 25025’s and keep a safety pin or needle with you to clear the nozzles.
That’s all anyone should have to hear about its rely ability
Year on myne, love it.
Just bought a few myself, light and fast. Big job tomorrow so looking forward to using them
I want to order the 2025’s. Where can i order them to ship here ASAP. I epically failed at not ordering the damw time i ordered my whisper wash. I want to order the mjet 5 system just for spraying chemical on driveways. Pretreat.
I love mine. I don’t think I’ve ever read a negative opinion on the Ultra Wash. Many here use them with 4, 5.5 and 8gpm and love them.
Do you run 2502’s on it. I have a 4200psi 4gpm and i think he may be hard on der concrete
Do you have the 2 or 4 nozzle bar?
My 4gpm/4k version came with 2502’s but worked better with 25025’s.
Now my new 5.5/3500 worked well with 1503’s, although I went ahead and bought some 2503’s to try out.
25025s work better on a 4/4 and are a bit safer to use lowering the psi.But I ran 2502s in my 4/4 for years and it worked fine…never even had a clogged nozzle.
Just used my new 16 inch whisper wash ultra for the first time yesterday. It cleaned great, BUT i found it fatiguing holding down the trigger, as the design kind of makes you use your thumb to do most of the work. Has anybody had the same issue and is there any sort of workaround for it?
I’ve used then for 20 years with no problems. Don’t use the linear gun that they come with, just a regular 2315
William’s right, I couldn’t quite figure out how a 2315 would work having a different angle than the handle but somehow it makes it a lot more comfortable.
Thanks for the tip! Hey whisper wash, if you’re listening, either a) take 5 bucks off the price and ship it with just a quick connect, or B) charge 25 bucks more and ship it with a more ergonomic gun! That straight handle is literally unbearable after 10 minutes of use.
