Which pump is better or the one to go with?
or
https://www.northerntool.com/shop/tools/product_200756187_200756187
Just go with the regular one. They run on sale all the time for $139. Sign up on their( Northern Tool) website for an account and they’ll send you coupons regularly… Don’t buy thru Amazon.
also this 5800 Series - 5 GPM - 12 Volt Pump - Pressure Tek ???
Buy the Northstar 5.5.
think i need an accumulator with that pump?
Don’t need one
I’m looking at the 1/2" braided poly 200ft and some manual reel . suggestions
Best i can offer as suggestion. Haven’t built one myself yet. But the beginners list appears to suggest that exact pump your looking at and has suggestions your looking for.
You made a thread earlier about a 12 volt system and you are still asking the same questions. You need to go read. I found everything I needed to know through old forums and asking of course but it seems you’re not even trying. Google
Why’s that? I’ve been using the second one he linked and I love it. It has a switch so I didn’t have to do any extra wiring, and it cuts itself off if it detects a leak. Also the entire head can be replaced if you burn it up, for $45 instead of $150.
That’s pretty legit.
