Not sure what tank you have or the actual issue… but we run a roll over vent on the tanks. The 3/8in hose vent barb with injector hose curled up to prevent leaking.
Do you have a picture of that? Can’t imagine it
Hook up the return line
or just cut that mess off and not worry about it
you get it figured out?
I dont disagree but if your just going to leave it stuck up in the air with a loop at the bottom to fill with water dirt bugs. He would be better off to hook it up. At least the vent will work
Yeppers. People do the most bizarre things sometimes.
Update: so i contacted Diego with MVP services on the advice of William. He told me like others here to go back to basics. I had the carb cleaned about 2 weeks ago by a local lawn mower repair guy. Simple guy. Did a good job. Or so i thought. Basically he didn’t tighten the bolts securing the carb which means no seal.
As the engine was running i saw the bolts from up top shaking freely🤨
I tightening the up and seems to be running without any hiccups.
All the advice really helped to narrow it all down that you guys.
How do you hook it up?
Fron the return port on the carb
