I have a 3/4 threaded tee pvc that keeps cracking. This is from my main water supply where i fill from customers spigot. What would you suggest ? Brass, steel, or galvanized fitting? Thank you. Happy holidays and happy new year
An extruded brass tee is what you’ll want. Are you sure the fittings here are not 1/2" NPT? The size should be cast into the ball valve bodies. You’ll also want to use hex nipples in the future rather than close nipples so you don’t mar up the threads removing and reinstalling fittings down the road.
3/4 stainless steel tee on ebay, they are pretty thick. just make sure you cjeck if threaded. Not too bad under $10. some are a 2fer.
Its not just the tee. Considering you got two brass ball valve hanging from it. You are going to continue to have problems if don’t secure piping
With advice like that youll slowly put yourself out of business! Thank you sir
Are you talking to me?
There’s no telling. He may very well be taking to himself and not realizing we can see what he’s saying.
Haha thats true
I was talking to you. It was meant to be a compliment. Im not good with words sometimes. I thought you solved his problem by suggesting to support that stressful area.
I feel you sometimes my comments are taken the wrong way. It never seams wrong in my head
