I need a short hose, 3 feet or so in length. Where in the world do I fid one of these?
Any vendor sells jump lines or just cut 3ft of your hose and have a parts or hydraulic shop put ends on it
Napa does hoses as well if you’re in a pinch
I did not know that. That is awesome. Thanks!
Yes sir
Do they consider them hydraulic hoses?
Yes. 1 wire ,2 wire,3 wire.
Farm services has them as well. If you live in a very rual area,like I do. FCI. Don’t know if there nation wide or not…
try Lunesdale Pumps, ive just bought one to fit my reel. they’ve got various different sizes and attachment ends…
https://www.lunesdale-pumps.co.uk/420-high-pressure-connection-hoses
hope this helps
I get mine thru Ebay and Amazon.
Look up pressure washer whip lines.
They have 2ft 4 6 8 10ft lengths.
EBay is couple dollars cheaper
Amazon Prime is couple dollars more but gets it to you faster.
Make friends with a hydraulic shop. Most of the good ones will do it right there for you
Central Kansas John Deere makes em, pricey but do right then and there
