I’m in need of some 3/8 threaded male to male to fittings to be able to use some of what I have laying around and then I need a boatload of stainless mpt female couplers that are actually stainless because I’m tired of these Chineseium things I’m having to use up rusting to my stuff and fighting with removing them from the lines while on a job.
I probably need more and will inventory when kids are awake. It’s 6am over here currently
While I’m thinking about it, I have been thinking about jumping ship with my 5.5 gallon 12v pump and trying some new ones out. I will need poly 1/2 inch female to 1/2 inch male camlock fittings too. My everflow used 1/2 inch male to 1/2 camlock fittings and that would be too convenient to be able to use what I stocked up on for new stuff
I shop between pressure tek, once in a while southside in KY, and once in a long while BCE cleaning. I won’t shop fittings on the zon either, sometimes they aren’t stainless, who knew the super cheap Chinese fittings were fakes?? Double check the fittings, difference between 304 and 316 stainless. also kleen rite corp I think they are called sells lots of stuff, got turbos there several times (they were the cheapest at the time).
I mean, if I’m looking to order parts online (I have a few local shops for parts/consumables) I order from pressuretek or powerwashstore. Hope this helps. I would consider any vendors local to you first.
