Just curious what you guys like to use, I have run into some really bad front stoops lately. I normally spray some roof mix on them and let them set a while then clean with a 2510 (4gpm machine) but some of them take a couple applications to get looking good. I assume most guys are using a turbo nozzle. I was planning on ordering one to try but figured I would ask first to see if there is something else worth trying.
I think I saw Brodie mention a small surface cleaner, like an 8". I looked in Home Depot the other day but I only saw the 12". I think Northern has a small one. I’ll check it out, of course you still need to get under railings so I may have to go with a turbo if that is the best option.
I am getting them cleaned but it is becoming a time loser, need a better way
The surface cleaner is faster and might even do a better job than the turbo. I use the 12" model…it really works great. You can just take a regular tip and hit under railings.
All the time. I plug these throwaway surface cleaners right into my short gun and zip over brick and concrete steps lightning fast. I think it cleans better than tips too.
It’s funny I read that thread when it came up and I never went back to read the end. Just what I was looking for, too bad it didn’t come up when I did a search. But then again nothing ever searches right for me. I am starting to think I don’t know how to work that either. LOL
Here is a section of brick wall we cleaned last year. I had one man pre treat a strong mix of SH with a dedicated 12 volt pump. I had two guys following with two 4 gpm machines, 25 degree tips. We were able to clean 1000 ft. of brick in one day and made 6k.
I hold my surface cleaner to the wall with larger brick jobs. You can do it solo but its faster with 2 unless you take the full handle setup off and put a qd in its place. Its wicked fast compaired to a 25° tip and lance
No. I calculate jobs by size and the amount of time it will take us to complete. I add 25% or more to the bid for unforeseen reasons like equipment failure, bad weather, or employee issues, things that would cause the job to take longer than expected. However, when everything goes as planned, and we finish before time I make more money.
