** everyone has there own opinions - I have yet to see a quick connect be pulled apart unless it is not connected correctly - some manufacturers actually send machine out with femal connectors at the pressure outlet. so you do what you feel comfortable with. and the friction loss is negligable on any of the fittings. main concern with that would be the length of hose your using!
Granted I don’t know your experience length, but I suspect @Innocentbystander knows more about washing than most on here by a long shot.
Rumor has it, that man has washed several. Several I tell you.
I’ve done it a handful of times years ago when washing drilling rigs and dragging hoses up flights of stairs. It stopped happening when I turned the quick connects around the way they’re supposed to be.
