Can i use a 4200 psi rated pump on a 4400 psi rated pressure washer?
But what will you do without those 200 psi’s?..……
Im not sure it will make much of difference lol. Looking at it that way
Oh no, here comes the peanut gallery.
It may be a stupid question. I know. Im new. I dont think it would hurt anything. But i genuinely dont know. I just want to know if it could hurt anything mechanically.
If you take the pump off, what part is 4400 psi?
Im gonna say nothing
Bottom line, you’ll be fine. What engine do you have?
Its a simpson 420cc
I meant to say that the pump is what is 4400 psi. When you take it off the motor there is nothing to create the psi
ok, that makes it clear as mud now
Put the pump on there and call it a day.
Will do. Thanks man!
