I like this for all around lubricant. I use it on everything, tools, pulling hose over nipples, general lubricant
but was wondering if anyone has a better recommendation for a multipurpose lube.
I’ve still got two cans that grandpa had. Good stuff.
Coconut oil…
Lol @Infinity
I like silicone spray for various uses. Works well when I have to free up a sticky sliding screen door.
I like the silicone lubricants around water also. It just seems to stay on longer
I’m not a motorhead, but I was told to avoid silicone lubricants on anything metal to metal, that they don’t hold up well to loads. I use lots of moly grease on my tractor, zeroturn, and my hair, but some people think poly or synthetics should be used. I use what is essentially animal renderings (fat) to spray my pto gears and shafts, supa slickerry.
I use 3in1 on my equipment in my basement, due to the humidity everything wants to rust. It is also great to keep your shower curtain hooks with bearings from rusting. I put some on a towel and wipe the top of the bar, then dab some on the bearings, then slide it around a bit. I reapply about once every 9-12 months. Haven’t had any rust in 3 years now. The curtain hooks HD/lowes sells all rust in the sauna my wife creates when using the shower.
It does wear out quickly.
I just use my 5 gallon drum of air tool oil that’s lasted me 10 years. Cheap and does the job. Buy a fiver and toss it under a bench.
With the exception of a small container of grease for packing bearings, some dielectric grease for the shertz box and a grease gun for bearing buddies, I don’t really have any grease or lubricating oils.
…or brake fluid😆
