What is the connection circled in the pic called? I want to add this to my 12v pump so I can change it out quickly.
LIXINTIAN 10AWG SAE Connector Extension Cable, (2Pack) SAE Quick Connector Disconnect Plug SAE Automotive Extension Cable, Solar Panel SAE Plug- 30cm/1ft https://www.amazon.com/dp/B07Y9G7N85/ref=cm_sw_r_cp_api_glc_fabc_AGBaGb13C5HB2?_encoding=UTF8&psc=1
