I was thinking about this today… Always thinking about finicky injectors how to get more concentration of soap sometimes with regular ds injectors…
I quick couple my injector in at the hose reel swivel, so I can remove when pressure washing…running a surface cleaner etc.
I use to couple it in about 8 feet further upline, right at the output of the pump…but anyway, what would happen if I put another one there again, and still left one at the hose reel? Would I be able to draw twice as much soap?
Good question. I haven’t used down stream injectors once I discovered x-jets 11-12 yrs ago but the first question I would think is can you just double the strength of your soap mix instead?
Besides that I would guess that your draw would be weak as far as PSI goes to the point that you will have problems maybe shooting it up on a house… But that’s only a guess.
If it works OK I wonder how many injectors you can put in line before it doesn’t work at all?
Yes ive seen the double barb injectors from espec previously. I once bought one of their super suds suckers, and it sucked, in the bad way… Did not last very long, like about a month or so…
Bob, I think what Lou is talking about is a bit different. It’s a 12v pump hooked up to a down streamer. Basically it forces chemical into the downstream injector so you can get a much higher concentration. You could probably make one of these yourself very easily.
I actually did think of doing that Micah… Did not know they already had it… Crap, I was already planning how to spend the million$ I was going to make…
