What do you use on stucco
I’m new to pressure washing and I’m about to nake a bid on a property that has stucco. Is there anything different I need to use, or different procedures. Thanks
Sent from my SCH-I535 using Pressure Washing Resource mobile app
gcpressure- you need to fill our your signature line so people know who there responding to. You’ll get more responses that way.
Thanks John I didn’t think about that
Nick @ Gate City Pressure Washing G’Boro
Pressure plays an important roll. High pressure may damage walls and roofs. So always choose experience persons.
How do you wash a house now?
Jon Karmazyn
Revive Coatings
Right now I use sh and then rinse it.
You usually need a stronger mix for moldy stucco. I can’t usually make it work with DS. I use a roof pump. Xjet would work too. The one time I did make it work was with Simple Cherry and F13. The F13 seems to boost the mix, but I don’t think you could use it with Elemonator. Would take too long to rinse.
Sent from my DROID RAZR using Tapatalk
Is it stucco or dryvit/EIFS? I did a stucco building a few months back with a roof pump and roof mix after 10 minutes the lower section in this pic is how well it worked (before rinsing).
I also did a EIFS hotel with an xjet and it worked alright. I prefer the roof pump mix and low pressure rinse from now on.
Jon Karmazyn
Revive Coatings
www.revivecoatingsPA.com
That helps a lot. What’s the difference of a roof pump.
Roof pump we use is a 12v low pressure pump that applies a straight mix from a separate tank. This way you can make the mix strong and not waste as much SH by having to mix it with the water through a DS injector. It is my go to for stucco jobs now.
That makes sense. Where would I be able to find a pump like that. I’m trying to learn
Bob at pressure tek can hook you up. This is a good system that will last you a while. ROOF CLEANING PUMPS AGRICULTURAL SUPPLIES / CHEMICALS PUMPS / COMPLETE SYSTEMS / KITS All our 12 volt pumps are manufactured to Pressure Tek’s specifications and are warrantied against manufacturer defects for a period of 6 months from the date of pu
Thanks that’s a huge help
What’s the roof mix did you use in that pic?
We use the All-Flo and can control the mix. AKA soft washing.
