So first off id like to say that this pertains to hard to remove stains that require scrubbing as i see a lot of pros say you need to do to get it all the way up or close plus the right chemicals. Do i just use any ordinary brush or is there some special one. Concrete stains
I just use a basic stiff deck brush. They have some stiffer nylon brushes that would probably work well too.
I have one of these too but haven’t used it a whole lot. It’s even stiffer than the deck brush.
stiffer the better i am assuming?
Just like she said, stiffer the better…
At least for concrete, you might also want to get a soft bristle brush for situations where something more delicate is a better choice. 1 pole - 2 brush heads.
