What are your go to or must have nozzles for wood?
I’m looking to setup a jrod specifically for decks and need advice for nozzle selection. I have 2540 for chem… I read that a lot use a 2510 to rinse whuch I also have. Would a wider fan for either be better? What else comes in handy?
Orifice size depends on gpm machine- myself I never exceed 1000 psi leaving the tip and most
have preference on spray pattern. I would never be less than 25 degrees. Hope this helps:D
Bill Sullivan
Bill’s Window Cleaning.
902-471-8008.
Thanks Bill for the reply… you replied to my other thread and I’m getting 1000 psi from my 2510 with 4.5gpm machine. If 25 degee tip is all I need… then I’m set. :slight_smile:
You should be good to go. We’ve kept the same size tips on our PW wands for 13 years. 2 dual lances, one short, one long, are very helpful for rinsing wood. A turbo tip is great for cleaning concrete/stone pads at the foot of stairs.
Thanks!
Sent from my XT1254 using Pressure Washing Resource mobile app
