I have a 7gpm Delevan pump. What amp fuse should I use with 10ga. Wire? Using a marine switch.
I am not a wiring guy, only passing along information. I believe my 5.5gpm pump has a 20amp mini fuse. It’s fluorescent yellow. I hope that helps, if it doesn’t, I’m sure someone will be along shortly
My 7gpm Remco came with a 30amp from pressuretek.
Yep, 30 amp should be plenty
