I forgot your in Miami rite ?
Water based sealer like ureseal and seal n lock is really the only sealers that are intended for FL
Yup I’m in miami. The customer doesn’t even know. The driveway to be honest looks great minus a few rust spots
Oh and its is ocean front not sure if that would make a difference on the best type to use I was thinking water based
Quick question what kind of stripper should I use to remove water based sealer??
Time.
Dads easy strip 5 gallons about $200 covers 800-1000 sqft
Dad’s works best with hot water, if you use it make sure to wear long sleeve and pants along with a mask.
Tape up anything you don’t want ruined near your work zone dads is very aggressive stuff it will strip anything it touches.
Thank you @florida_condo_cleani
I am currently looking into using this product FluoroSeal as it is water based and compatible with any previous sealers and it can be applied to wet surfaces. This means you can clean and seal the same day and no need to wait around for the surface to dry before sealing… and definately no need to return the next day to seal.
Works for concrete too ?
He is an aussie I believe, shipping would kill it for you.
Yes Sir… great for concrete driveways etc.
Here’s a link
Not sure if these products are available in the US but I’m sure there would be something similar on your local market.
