Hello to all the new and senior pressure washers!! I am completely new to this.
Heres a small back story… wanted to wash my driveway so i bought a used Yamaha MA190… within about an hour of washing I started to loose pressure and then found these pieces next to the washer.
My question is… am i missing any other pieces that flew off? (As i cant seem to pop it back in place, the white cap wont seal properly) doesnt seem like a hard fix? Thank you all in advance. Any help would be greatly appreciated.
You probably won’t receive too much help on this forum as this is nearly 100% professionals here. So there’s a good chance that no one will have experience with this style of pump I’m afraid. But, perhaps check out AllPartsInc website and punch in either your pump identification numbers or your pressure washer’s numbers and you might be able to get a good exploded parts diagram with part numbers in the event you need to order anything. Best of luck!
