That’s a good price, but never heard of that company. Looks like a Honda.
Sent from my iPad using Tapatalk HD
You did a great job, looks awesome … I am looking to do something like that in the future
I’m sure it is knockoff made in China … But for the price with no tax I’m probably going to give it a shot. I haven’t price out the rest to make it (gear box, unloader, frame, etc) but I figure I could made a 5.5 gpm @ 2500to 2700psi complete for under 1200
Great looking skid and very neat pickup setup
Sent from my SGH-I747M using Tapatalk
The gas cap thing isn’t an issue for me.
Can you find parts for them?
How much is the warranty?
Thanks Sean. Let me know if you have any questions when you start your build.
Thanks Cameron.
The parts aren’t hard to find. Ebay has a good selection of parts for these motors. I payed about $10 for a replacement key switch. I can’t remember the warranty details but I believe it was an in store replacement for up to 2 years for an additional $30-$50? at time of purchase.
Thanks, I will definitely ask you when I start the build, hopefully 2014 will be a good year that would justify it LOL… I am curious what pumps and gear boxes you used … BTW I was sitting behind you in the Maryland event next to Russ … Also, your twin hot water rig is sick… I was checking it out before I left on Sat on the outside and when I pulled out someone was checking it out on the inside LOL
Lol. Small world I guess. The event had a great turnout and alot of faces I didnt recognize. Thanks again. I ended up giving a few tours of the flatbed on Sat. It was built as the replacement for my 16’ trailer that I had pulled for years. I planned on building another, but decided to go with the pickup skid instead. It will keep my guys out of DOTs regulations.
I ordered the pumps and gearbox from Bob at PT. They are TS2021-N-GR
[MENTION=7882]Chesapeake[/MENTION] I forgot to ask what PSI are you getting out of those 5.6 GPM pumps? … I’m assuming that’s enough to go residential driveways with the right chemicals … Also, what you thoughts on the 16hp electric start motor I posted earlier … I did notice it has the same 420cc as the motor you used
I have the unloaders set for 2600psi. I’m sure you could squeeze another 200-300psi if you wanted. You’ll have no problem doing residential driveways and sidewalks. We often run a 20" surface cleaner off these pumps. I’m not familiar with the engine in your link, but it looks comparable to the one I use. Thats the first I’ve seen one listed at 16hp. Most are listed at 13-14hp. All these are chinese made knockoffs of the Honda gx390. The one you listed is manufactured by Lifan, which is one of the better names in these chonda engines. A lot of the pit bikes 50cc-140cc have Lifan engines.
Oh OK i got you … they are both gx390 knock off with 420 cc … The one I posted the HP rating is probably a exaggeration just like honda does on their pressure pros units LOL … I thing I will start calling the knockoffs Condas GX390’s
