Water dragon pro/mini cube
Has anyone out there had any experience using either the Water dragon pro cube or mini cube.
They seem to be having issues with them here in Australia… and the last I heard was that the Australian distributer sent them all back to the states.
In theory they seem like a great idea… but that unfortunately they appear to be a lemon.
Any info would be greatly appreciated.
Mini cube?
Nevermind, I see it.
Those machines are alot of fluff for something you can build for 10x less with the same results.
Not sure about the mini cube but with a quick search I found the pro.
I personally don’t like how it’s all boxed up. You loose your ease of accessibility to interchangeable parts when things go bad.
Totally agree… accessibility for servicing or replacing parts would be a pain in the you know what.
In theory they are a great unit… but in practical sense they’re a complete failure.
Back to the drawing board Water Dragon designer’s!
There a failure because the distributor won’t service them. You ain’t sending that back to America for a yearly “recommended” proportioner recalibration .
Im not sure I have what is called the pro cube but I have a booster that is powered by a gas engine that is in a box like that.
What have you heard about overseas?
I would say they have issues like anything else out there but overall I like mine. When running properly it’s incredible.
The accessibility is definitely a challenge sometimes but get used to it after a while. A forklift is needed anytime anything goes wrong in that box. Only issue I have is you can not just pull the canister of the booster off with mine; have to take the pump out, which requires taking 4-5 other steps before you get to the pump. A 20 minute job takes at least 2 hours to do. I do like it though and Paul was great helping work out the kinks early on.
