Hi. Doing this driveway soon, it’s made of old brick. Should I just soft wash and rinse? or is using a surface cleaner ok? Let me know what yall think.
Should i sand this driveway like you would a paver drive?
Blow it with blower to get loose dirt gone, surface clean 2500 or less. You’re going to spend 70% of your time rinsing probably. A fair number of low spots, so some of the dirt going to settle in there. I’d probably use a medium pressure fan tip to rinse so you can kind of sweep the dirt along as you go… Shouldn’t really need to re-sand unless they say they want up front. If they do, going to need to do differently. Come back and tell us if so.
