What you guys do when part of the house in vinyl and part brick. Front brick, rest is vinyl. Seems like there’s plenty of those around here.
Should i use brick cleaner to clean front and normal soft wash for rest? Or should i just spray brick to with soft wash solution? In most cases brick is clean to begin with.
Before i just washed all the painted surfaces and just rinsed brick, but i don’t know if that’s correct way
We just spray the brick with our house wash solution. As long as the only issue is dirt or mold, moss etc.
