Hey all, I had an estimate today where the customer has painted wood trim, and stained siding. He wants to have ot washed to prep for painting the trim, but he is not re-doing the siding yet.
Im worried the house wash mix may have negative effects on the siding. I know it would be fine for the painted trim and eaves.
Anyone have experience using SH on stained wood siding? I have and am still searching on older threads
I’m going to make a video of the five or six test bottles I always have when I show up to a new house. When in doubt a test bottle of your mix will answer 99% of your questions when it comes to stuff like this.
Agreed! Customers will appreciate it! Ask them if you can do a test in an inconspicuous spot and show then the results. I’ve done that and had customers write reviews that we really cared for their home.
The SH gets mixed up weekly or bi weekly when I fill the tanks.
Everything else is stable for a long time. There’s only about a cup of each in those bottles. And they’re handheld pump sprayer bottles since they’re air tight.
Just prewet the wood and hit with your normal HW mix unless stain is really bad. Down at bottom where it’s green you’ll probably need to use a little pressure, like 300-400 psi to get all the green off. Maybe not though.
So this job with stained wood siding is far away, i will do the spray bottle test before applying but are the odds greater that i’ll have to cancel or that i’ll be able to wash? If it’s too risky i’d rather cancel now than drive back and forth but Racer you say if i pre-wet then apply normal housewash mix it should be ok? Very moldy stained wood siding. I normally walk away from stained wood but this is a regular gutter cleaning customer.
If they’re a regular gutter cleaning customer, why not tell them you’d be happy to test (and wash) it the next time you’re out…that didn’t get that dirty since you were there last, and they didn’t all of a sudden care that it’s mildewed, lol
I think you’re going to have to hit a couple of times with strongest ds you can get. What’s up in the first pic, that area at bottom of downspout that looks like fresh paint? That looks good there.
I’d prewet and try a section. I’d tell him there’s a chance that it may look sort of molted looking in places. But see how you’re test goes. Do a decent sized area ds your mix.
