Any use the metal strip with nozzles in it to do concrete work? If so how do they work… I wouldn’t mind having one as a backup?
The good: I love it for rinsing after I run the surface machine. Quick and easy.
The bad: since it is a quick connect, it always gets dirt in the nozzles and half ass works.
If you get one leave it permanently attached to a wand and gun so it doesn’t clog. Also might be a good idea to use a inline filter at the wand, they clog super easy.
Sent from my iPad using Tapatalk HD
Will they actually clean the concrete by themselves?
Not really. They will move the surface dirt super fast, but don’t do a deep clean.
Hate them.
i had one that i used to rinse, and it clogged all the time. then i found the magic of the ball valve. haven’t looked at the broom in years.
Ball valve is so much better…but hey…whatever floats your boat.
Why ball valve? Why not just a 40 degree tip?
Sent from my DROID RAZR using Tapatalk 2
You can adjust psi with a ball valve, gives you the ability to rinse with impact.
I prefer a variable pressure wand.
Good deal, whatever works for ya.
I owned a Wash Broom for about 45 mins and took it back. This was very early in my start up days. Some people like them but I can’t really see a use for them. After you run your SC rinse with a Ball Valve. Its very controllable and saves a bunch of time.
Does the ball valve have a wide spray pattern?
Not really.
