I’d like to get a wand extension for my pressure washer. It’s currently only 19” and a new surface cleaner purchased last fall made me realize I need a much longer wand. Where do you guys typically buy this kind of thing? An amazon search didn’t produce anything and Home Depot is more expensive since than I think I should pay for a 36” extension. I assume 36” will work to reduce the constant hunch I’m in when using it for driveways and the like. Thanks!
A surface cleaner doesn’t use a wand unless you have some home depot gizmo. 95% of our washing is with 6 inch wands.
http://www.pressuretek.com/aluminumlances1.html
Well, it’s more of an amazon gizmo than a Home Depot gizmo. Lol. I’m starting small and it’s working so far so I do need a wand extension. Thank you.
Northern Tool carries pretty good selection if you have one near you or just order from link above.
Check out our website for various lances and wands so you can stop breaking your back bending over with your surface cleaner.
Lol. I call them the harbor freight of washers and 10 minutes later they join the forum
Coincidence?
I don’t care. Everyone has to make a dollar. There are enough new guys here that don’t know any better so you may make bank.
You lost me. Who?
Are y’all saying not to buy from them?
