Hey All,
I originally produced this video to show how to prepare a driveway for the F9 Rust Removal process but thought it would be good for some of you to see how to properly power wash any driveway.
There are a few techniques you can use if you watch closely, like how to keep the hose off your surface and behind you at all times. This eliminates the need for a hose guy.
I also use a double-direction pressure washing technique, going faster on the 2nd time over. This helps to reduce any possible surface cleaning lines and makes everything come out a little cleaner.
Use of a good degreaser allows us to adjust the Landa Water Jet up higher so the impact of the tip to surface spray is lower, yet wider… which allows me to work faster while reducing the possibility of damage to the concrete.
If you have any questions, feel free to post them here.
