What do you think about this pressure washer for sale. It’s a 5gpm 4000 psi ar pump.
It seems to be in good shape…
Yeah it seems like a pretty good deal.
This washer is setup to bypass through a water tank. Is it possible to set it up without a water tank? My rig does not have enough room for one right now. I know it is better to have a tank, but i have no room for it.
As long as the water supply you are hooking to is more than 5 gpm you are ok without a tank. You should be able to run the bypass right back into the pump. Just don’t let it run for more than a minute without pulling the trigger.
