Hi I’m trying to figure out what attchetmets and what not I might need to soft wash with my ryobi 3100 psi pressure washer. I’ve found a pressure washer flow control valve as well as a foam cannon and soap tip for the ryobi power washer I have but I’m still confused on what I will need exactly. In need of dire help please someone let me know if you know anything about ryobi power washers
This will get every bit of that 31 hunnit psi up that bad boi!
If you’re talking for your own house/car a foam cannon. If you’re talking professionally, just walk away!
Awww man I’m a little more adamant than that. Can’t just give up haha, I’ll do whatever is necessary to do it professionally gotta make money somehow am I right
Oh wow, where do we start?
Your machine won’t work for soft washing, sorry. A minimum is a 4gpm/3000psi belt drive with buffer tank. The more GPM the better.
Try Forever self-employed on YouTube. Your setting your self up to do 10x the work for 1/10 the money but we all have to choose our own path.
How so? I downstream with a direct drive and no tank…no issues!
Yea I think he was quite dramatic with that post as he was running a direct drive until about a month ago lol. You trying to scare him off @dcbrock?
You have the luxury of good water pressure from a spigot. I’ve run into several here that only put out 2-3gpm. When my 4/4200 started cavitating on a regular basis, that’s when I got the buffer tank.
God I hope not lol. That’s IBS job.
I wish you could reply with just three letters. lol is what I would have said.
…lol
…Omg
That’s just plain mean…lol
@dperez, @Hotshot. I don’t internet too much. And when I do I’m usually drinking. But that was a…good idea.
@sgb. I’m the most non internets fella you’ll find. So cheers dude.
Either that guy is most jacked guy on the planet or that pic is photoshopped. He has it fully extended at a tough angle with no belt.
I had that big yellow noodle before to do gutter clean out and at that angle fully extended you better be ripped…lol.
It’s a piece of cake, just dont move it.
He clearly just started… nobody can smile that long using one of those.
He’s smiling because of all that $$$$$$ he’s going to make
