Unloader valve settings
DIY guy here. I own a Simpson pw rated at 3,300 psi and 2.4 gpm. I am getting 2,500 psi (trigger open) and 3,000 psi (trigger closed). Are these pressure readings realistic and safe for the machine? Thanks
Depending on what size tip you have in there, that sounds about right.
