Udor vs GP?
It’s time to order an 8@3500 cold water machine and I’m a little confused. I was going to order a pressure pro with the honda and a general tsf2021 but the guys at the power wash store have the honda setup with a udor gkc 30/24 for basically the same price. I’ve got no experience with the udor pumps, but what I’ve read tells me they might be a little more durable? Which would you guys buy if it were your money?
Jason, I got a Udor 5.5 gear driven and put it on my Honda GX390, and I absolutely LOVE it! If you want to check it out, just give me a call and I’ll run it down to you to look at.
JohnT and a couple of other guys on here really pushed me over edge when I got it, and I’m so glad they did! There’s an older thread on here that I’ll send you (if I can find it) where JohnT talks about Udor’s awesome customer service.
Jesse
Atlas Services
Exterior Cleaning Specialists
North Carolina
Most of my pumps are GP pumps but my 10.5gpm pump is a UDOR. If you were to open up side by side a UDOR pump & a GP pump you will see the UDOR pump is a much more solid pump with larger gearing etc which makes it more Durable. I also had @ one time a 11gpm @4800 psi UDOR pump that was valued about 4g. This pump was so solid it weighed over a 100lbs and you couldn’t destroy it if you wanted to.
So for the same price I would take a UDOR over a GP pump everytime.
