Only use non detergent 15-40. You can get it at oreillys. Nothing else.
You can use both Oil’s 15w40 Non Detergent Or 30 Non Detergent. It will also state it on your manual. I spoke to Randy over at Udor regarding this, and he said both are fine.
Also your new pump should come filled with oil
Thanks, sight glass was at 1/4 full, should have been in the middle. It may have some mileage on it. It was sold as new though. I’ll see what the hour meter says.
