It won’t collapse it’s hard plastic but not pvc hard. I don’t see sh hurting it either. The main thing will be getting it over the hose barb which I also don’t think will be a problem if you heat it up a little. I’d say it’s somewhat similar to pex but isn’t blue or red. It’s a foggy clear and comes in smaller sizes than what pex does. It’s usually sold by the foot.
I will get some tomorrow, thanks!
You are missing the forest for the trees. If it is hot enough to collapse reinforced hose inside your trailer, it’s too hot period. Put in a RV door or vent on the sides, or an inverter hooked to your pressure washer battery and a fan. Your machine will run much happier with fresh air.
I do have one of those Lasco fans that belts out the air, not sure what size inverter would power that sucker.
Yep. Get that lil trailer cooler by any means possible. If your lines are lying flat and collapsing due to heat, and everyone else on here runs the same ds tubes and aren’t. Than when in Rome…It really ain’t rocket science friend.
Does trailer have a roof vent?
There’s plenty of 12v roof fans from the RV industry also.
It’s a cheap little trailer, the roof is flat and thin aluminum sheetmetal. I’ll try the fan thing once I figure out what size inverter is needed.
I call bull crap. There all made outta cheap aluminum on top ,they sell 14" ,12volt power vents for it all day,every day. Any trailer place or rv store sells them. Its easy ,cut a hole with the Givin template, slap it in, use a good self leveling rv caulk ,two wires to battery and done.if ya really wanted to do it right, run your exaust through the side wall with flex pipe.
Side vents will help in travel, MaxxAir or Fantastic Fan (i think) are the go to fans. You can make a computer fan in a roof vent work to help move air. You can get fan to run off trailer hook up.
Dicor for any vent you put in.
Dude I’ve seen your trailer on here. Your over thinking this. I use a cast iron fire place in my house that will get to 1000 degrees if your not careful, from October till the end of March. And sleep like a baby every night…they make products to cure your problem. You just need to research a little more .And to be honest, you know this ,I hope @dcbrock,Aka Ricky booby.
That stuff is awesome
Eternabond good stuff too for seams… nasty sticky stuff, borderline pain depending in the day… but its good
I had problem with heat in my 5x8 enclosed .Had to put roof vent , rv side door , fuel door and exaust through the floor. Ebay has used cheap rv doors in different sizes .
¹¹111111qqqqqqqqqqqqqq
Yeah, neither of those are fond of 12.5% SH. I have to stick with some form of plastic.
No. Just no.
