Ok I see
Got it adapted to a regular injector.
Made a bushing by hacking the end off of the original hose barb, and tapping an 1/8” npt thread inside of it.
You’re the son I never had
How do you keep it from back feeding
Center position on the 3-way valve turns it off completely.
Will it hold the pressure? That’s awesome
I will only use low pressure (house wash) tips with this gun. So it will never have any pressure on the soap inlet.
You are going to hate that 3 way ball valve in no time at all. Make sure you have a couple up in the bucket with you in case it breaks. Here is another one that works great but it doesn’t have an off position
https://www.amazon.com/gp/product/B00QB1GU88/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
