Just ordered new power washer with 4gpm and order parts from pressure tex.Is there a good video on a basic trailer set up and do I need a buffer tank .
No buffer tank needed. Search trailer setups on here and youâll see lots of great ideas. Also search downstreaming and whatever comes to mind. Youâll find your answers and learn a lot in the process. This forum will help you a ton
You donât have to have a buffer with a 4 gpm but it will definitely make life easier. I would never run without a buffer.
What he said^. You donât need it but you will find yourself needing one when the water flow isnât sufficient at the place you are working. Always check the flow out of the spigot before hooking your machine up
Soft washing is just a way of washing with low pressure. You could have a 5000 psi pressure washer and soft wash with it. You adjust your pressure via nozzle selection. The larger the orifice the lower the pressure. Learn how to read a nozzle chart and you can then select nozzles needed based on the task at hand. You could also soft wash using a garden hose or a 12 volt system. A pressure washer is the most efficient method when it comes to soft washing so thatâs what most use. A 12 volt is great when you need a stronger mix than what you can down stream.
Do I put a pressure gauge on it or is there an easier way
