I’m not patient enough. Maybe a hose buddy made from a roomba could do the same and keep me company
How does this setup work?
With the 2 way ball valve in the closed position you turn the 3 way ball valve to the desired chemical you want to apply. Then turn that same valve to select a second chemical. Open two way ball valve to rinse
We use it to wash fleets , lay down 1st chem then remote switch to second chem then lay it over 1st chem then rinse for a brushless wash, the 3rd chem is for ceramic wax. all the while its application of chems is 1250 psi , the rinse pressure is 2300 psi. Saves us alot of time from brushing. We wash over 1500/ 2000 tractor trailers a month and it couldn’t be done without it or a tremendous amount of man power with brushs. We also run 2 step guns that dezmar posted , same concept but one less chem choice, its just easier for the new guys to use, the remote you have to be a little more methodical with chem applications.
