TSF 2021 torque issues
The torque says that it should be 95 fr lbs !
However that much torque seems to put too much pressure on the check valves and causes it to bow hereby destroying the valves
Has anyone had that problem or maybe tell me what am doing wrong?
Are you sure everything is seated properly?
just tighten it down real snug. then if it did happen to leak, give it a bit more. it just can’t leak, no real need to get crazy tight.
