For some reason I am unable to use the search feature with my moble device since the site design changed.
I have seen it on a post in here before. What DC heater do you guys recommend to run in your trailer for those cold nights? Unfortunately I have to store my trailer outside.
What you could have is one of them battery jump boxes and have it charging. Then run a 12 volt pipe heaters off it. If you want the pipes not to freeze. Also drain all water out of the pipes and unloader. That’s what happened to mine this year. I had just a little water left in the unloader it busted on me. So I had to get a new one.
