You should pm im sure i can get you a better deal. And faster.
It’s takes the same amount of time either way is our point. It takes X amount of time to fill up and X amount of time to use it. Those variables can’t change unless you speed up the fill up. If you’re washing, you need to have water filling your tank at the same time. I can run two 8gpm machines all day off of a 65 gallon tank and never run out of water.
Are you saying you’re stopping every few minutes to go fill up the buffer tank instead of leaving it connected?
That’s the point…it’s filling you at 5gpm, you’re using 8. If you stay connected, you’re netting -3gpm, so your 325 tank would allow you to hold the trigger open for nearly 2 hours…
There’s ALWAYS math
I refuse to accept your version of the truth. Agree to disagree.
True. I dont always have a water supply within 300 feet so I have to truck and refill later anyway.
This is the counter offer from the people that offered me the 8gpm/4000psi unit for 13k by itself. I told them I found a supplier that had a full on trailer for 13k. The delivery would be 1600 so about 15k. These guys figured theyd just charge 15k anyway, 13k wouldve been a better counter offer.
