Titan 4312es installation specs?
about to buy a 4312es but was trying to find more info on it first. I see some info where they want 6 gauge wire to be used but is there an install sheet somewhere ? I assume a fuse or circuit breaker
Circuit breaker 40 amp. Run power from machine battery to breaker and from it to reel. And if you have multiple, can just go from reel to reel.
and 6 gauge ?
If that’s what they call for. Sounds about right
I just installed mine recently. Power and ground straight from battery to the reel. Used about 20 feet of 6 gauge with a breaker as mentioned close to the battery.
