Really cool video!
Can I ask what your mix is? What nozzle you are using? Do you downstream? What type of machine do you have?
Super cool video good job
House looks great. We don’t have much of the vinyl siding here, mostly brick and limestone, they don’t clean that easily. Just curious what do you do to keep the mix from causing clean speckles when the concrete underneath it is that filthy? Nice job on the lapsed video too.
O
I dont do anything with the back patio, just rinse the foam.
I tell the client what will happen if they don’t ad the back patio.
If i have to come back the price is higher, since it is an ad on. In this particular case, he said he had a small pw and he could take care of it.
So u dont even rinse the patio off for them?
The time lapse is too fast. Next time try a slower setting and you will probably like the result even better.
Try this:
Just rinse it.
Ty.
I don’t have a GOPRO but this will help a lot.
I use VideoPad Editor
Where do you get the foamer tip?
U use a whole gallon of soap in a 5 gal mix?
Yes watered down.
I have a foamer that beeen using for years, so i got down my mix.
Pretty sure he means a gallon of water with
Soap in it
Thats what i was thinking but was like
Do you use a 0 degree nozzle even on the lower stories?
Yes 50 and 40
Usually 50 so it wont splatter too much
Question from a newbie… My first house I moved the barbecue so far away it was sad… I feared that the mix would affect the barbecue. This one is really close, am I going a little overkill moving it so far? Just rinse it after and it’s fine or?
the bucket is 5gl
I fill it up to the 4gl mark with SH, I can see the 4gl mark
Then the rest is about 75floz of detergent.
So I would say total mix is about 4.5gl
Never reach the top of the bucket
