Guys what’s your biggest fleet contract and how long does it take you to complete it?
When we were doing them, we had 33 big box trucks, and 2 semi’s. Took 3 1/2 hours two guys.
Sent from my iPad using Tapatalk HD
Depends on the wash job they are expecting. Some want everything brushed, others are ok with just a pressure wash and only brushing what is needed. (Chrome, windows and mirrors) We wash some that want it every other week. That’s 12 semis brushed every time about 2-2 1/2 hours. Then we have another account with 30 pieces 1 x month. Very little brushing about 4 hours.
it totally depends on what they want done and are expecting, to be honest.
We do several fleet accounts that range from 100 to 300 units. When the fleets are this large you never have an opportunity to do them all at the same time because the fleet is spread out.
That’s insane! Lol! Is that brushing them or two stepping?
We do what ever method is needed, some two stepping but mostly single step and some brushing.
I am new and it is taking me WAY longer to do a semi. I have 6gpm. What the heck am I doing wrong!?
Aeast54
Are you using cold or heat?
Sent from my SM-G900V using Pressure Washing Resource mobile app
I have a heated pw’er but it seems like it takes me just as long with heat and the diesel is expensive! I only tried heat when I first started. Maybe I should go back to it since I’ve got a better system of washing now. I’m guessing you suggest to wash hot
Aeast54
Heat and the right chemical it should take you no time.
Thanks. Definitely need to look into a different chemical.
Aeast54
So…“You can’t do fleet if you don’t have the heat.” Right? lol
So…
If you spray it with cold,
the dirt will still hold?
All Clean Power Washing Solutions, LLC
813.528.2219
So…did I say cold water wouldn’t work? No.
So…
If the waters not hot, you’ll still see the spots?
