This transfer pump is the cats meow
https://www.zoro.com/finish-thompson-drum-pump-115vac-13-hp-60-hz-efv-40-s1-kit/i/G3393354/
I have not used this for long so not sure of longevity, but holy cow. I have a 3/4 banjo camlocked hose into SH tank and into a 3/4 banjo fitting on the pump itself.
I used to transfer using the Ryobi battery powered transfer pump. I would go through 2-3 a year after rinsing religiously with water. Hoping this one lasts longer but holy cow. Transfered like 30 gallons of SH in must have been under 3 minutes. Total game changer. Would have taken me a good 20 to do so with Ryobi.
…dont ask me what I paid in shipping :face_vomiting:
Looks to have 316 stainless steel and Poly inner workings, so I am sure it will last just fine against corrosion but i’d still rinse with water every time for my own sanity just because of the price tag. A 17gpm transfer sounds like a huge step up from your typical diaphragm pumps for sure! They also thought through it with things like an extended 12 ft power cable. It would bug me having to put caustics too close to an outlet. Extensions are a thing but that’s a nice touch.
Thanks for sharing!
Definitely rinsed with water afterwards! Too spendy not to take care of it
Its like a soar dingy, ya just can’t beat it, we’ve had ours for years n years and transfer SH, heavily sodium hydroxide based, sulfuric, phosphoric,ABF and hydrofluoric acids through it without a hitch. Like you said, make dang sure you rinse it out good,especially with SH. Expensive ? Yes, but Its worth every penny and you’ll spend it anyways on sub par transfer pumps imo, Knock on wood.
We push our chems through a 3/4 " x 50’ flexzilla hose with no problems reaching our chem tanks on the rigs.
Yeah I’m hoping it doesn’t die as easily as these Ryobi transfer pumps. The time savings alone make it worth it. I love not taking 8 days to fill my 55 gallon tank :joy:
