7000 watt generator, 240v, 10 GPM booster pump for soft-washing. Wow. I don’t know if he’s on any forums.
Lol this guys YouTube channel is great. The king of overkill
I’m so clad I’m not a trendy person.
That guys got $10000 worth of stuff that SH will definitely destroy over time . And I can do it all in the same amount of time with a $14 DS injector
I think I watched all his videos over the weekend. He doesn’t talk about the particulars of his business, but it looks like he’s set up to be as efficient as possible. He’s a got 1 or 2 clips where he talks about being done with a house wash in well under an hour.
A 2500sqft house is about a 30 minute job normally.
I’m not knocking his set up each to there own . I’m just saying a $14 injector will make you the same amount of money in the same amount of time . Doesn’t make much sense to me to over complicate things. Especially when you have to put it in someone else’s hands . The more complicated the equipment is the more problem you will have with it and the people using it
That setup could really tear through some roofs in no tome but other than that I just don’t see it being any better than a downstream setup tbh
Agreed. I’m in no position to judge his setup. I’m not even in business yet, lol. I looked up his generator… it’s over $5k. I don’t know what all he runs with it. Maybe he does a lot of commercial work, I don’t know.
That big generator and 240v booster pump that does 10 gpm does seem to shoot a decent distance, but there are plenty of guys using a 7 gpm off a 12v battery. Speaking of which, is 7 gpm the max flow booster pump you can run off 12v? Seems like all the setups I’ve seen are in the 5-7 gpm range.
I didn’t watch the whole thing i stopped when he started blasting the roof with 10gpm . That is not how you clean a roof . It’s just him showing how far he can spray.
If you sprayed roof mix 3-5 percent that way . All you would do is kill everything including the lawn .
It’s a fancy house wash unit to me .
Same thing is done with an 8gpm machine and a DS injector. They rest of his stuff is more for bragging right than anything else
Went to his website and he has stolen pictures as his before and afters. Lost all my respect with that.
I can’t find his website can you link it?
I take it there very clean at 7.5 minutes a side.
Actually about 15 minutes is spent on the fronts and entryway. The rest of the house goes really quick
key stone pro wash dot com
Well, regardless of whether he’s a power washing poser, or a plagiarist, he’s got some nuggets of wisdom when it comes to plumbing and equipment setup.
I like that drip free bleach quick connect he’s got.
If there’s one thing I’ve learned even before opening the doors, make sure you own the rights to pictures on your website! No stolen valor here!
lol he just sprays 4% like it’s hw mix all over the grass and plants and it shoots over the roof with no regard what’s on the other side. How is he in business still? Must own a landscaping company too
Honestly that’s what I thought. Wastes so much mix and sprays it where it doesn’t need to go like bushes and grass lol
