Last year I use scotch brand and frog tape (exterior). For PW I think either one was fine, but when I was painting/staining they performed a little poorly. I also used an automotive masking tape that seemed to be a little better.
Other than the caulk or razor slice tricks, does anyone have a good recommendation on an exterior tape that takes water and chems as well as paint and stain and sun?
My biggest issues are those post lights on decks, some paints readily adhere to that plastic. I double bag the tops and then tape the bottoms. Tape has to last at least 10 days due to possible weather/rain delays (most tapes say how long they can be on for).
Thoughts, suggestions, or recommendations would be appreciated.
How are you liking your Hydromax and the Kohler? That efi engine is a beast. I haven’t done a bucket test yet but I bet I get close to 9 or 10 gpm when low pressure washing.
It’s an absolute beast. I’ll have to do a bucket test because I still haven’t done it yet. I’m able to surface clean around 2000 sq/ft per hour. I’m not sure if that’s good or not but it’s freaking amazing for me compared to what I was achieving before
